I checked the related fuses and there are all okayMy driver side door has no power to controls ( windows, locks, mirrors, heated seats).
Any ideas what might cause this?
Thanks!
Thanks for the reply.I would start by checking connector c3 at your left dash instrument panel fuse block.
Here is the link to you tube video, hope it helps.Thanks for the reply.
I found the problem. It was the Drive Door Module (DDM) fues located in the left dash instrument panel fues block.
I did replace the window switch module and that was not the problem but did video if anyone needs it. I plan to put it on you tube but...
