Ecmi powers it appears to be part of pcm (ignition) and in particular the flex fuel sensor. Before it left me on the side of the road the check engine light came on and the code was
P0178 Chevrolet Fuel Composition Sensor Circuit Low Frequency, I didn't think much of it I was headed to the beach for a week. Note when the Yukon left me on the side of the road, it would not start with starting fluid and the gas gauge went from Full to empty, replacing the fuse fixed all that, but you know a fuse blows for a reason, so I concentrated on the flex fuel senor because of the code, so under the thing I go to look at the flex fuel sensor wiring and the problem was easy to see, turns out when the transmission was rebuilt a year ago they did not put the harnesses back in the proper place and over time the harness sagged until the front driveshaft broke the wires going to the flex fuel sensor I spent the rest of the day repairing the harness and tying it back so it doesn't happen again.
