Does the avalanche have the same abs brake system as the 03 tahoe?
my dad is having issues getting several codes
C0241 - EBCM Internal solenoid or control valve circuit
C0245 - PCM indicated requested torque fault
C0251 - EBCM Internal solenoid or control valve circuit
C0246 - EBCM Internal solenoid or control valve circuit
C0242 - EBCM Internal solenoid or control valve circuit
C0252 - EBCM Internal solenoid or control valve circuit
C0268 - Pump motor circuit open/short
i changed both front hub bearings with speed sensors about a month ago
everything ran fine then the abs & brake light came on
i read that this might be either a faulty control module or bad ground
anyone else have this issue and what was the fix?
i thought i had read on this forum that something had to be resoldered in the electronic part of the EBCM
thanks for any help
thanks for any help
