1999 Yukon Denali Front Bench In 98 2Dr Tahoe
neosoul
Las Vegas
Guys I just saw a 99 yukon denali bench seat where the middle seat is also the center console, what problems would I run into trying to put this seat in my 98 2 dr tahoe. I know I would lose the ability for the seat to slide forward for passengers to get into the rear of the vehicle, other than that are there any other hurdles. Also would that rear seat also be compatible? Sorry for being lazy for not searching this forum
N
neosoul
Las Vegas
Can someone at least tell me if I'm correct as to whether or not the seat would slide forward to gain access to the rear of a 2 dr on the powered version of the 60/40 bench seat.
Back N Black
Houma, LA
I seriously don't think that it will slide forward enough. That bench seat was not meant to allow access to the rear seat since the Denali was not available with less than four doors. It might slide forward enough for a kid to climb back there, but not the average adult. On top of that, if it's a power seat, and I'm sure it is, then that's quite a bit more wear and tear on the motors. You would likely wear out your motors prematurely.
N
neosoul
Las Vegas
thanks for the reply, I appreciate it.
Back N Black
Houma, LA
Not a problem brother! I haven't tried it, nor have I seen it done. Just knowing that they weren't designed for a 2 door, that's what I believe. I did just find this though: https://www.google.com/search?q=2+d...C&biw=1366&bih=631&dpr=1#imgrc=phwyXws8mM8GsM:
search
search
DefiantOne
