'07 Yukon XL Rear W/S Washer Refill?
BSarteSr
I have had my 2007 Yukon XL for a while and never been able to get the rear W/S wiper washer to spray any fluid. I have looked in the manual about it but noithing there.
Any one know where the rear w/s washer gets it fluid from? Hope not from the front as this is a ways to travel! :)
Is there a rear washer bottle somewhere? If so, how do you refill it?
Bruce
bjc7jr
PA
No rear washer bottle that I know of.
blackbeast03
NC
i had the same problem. turned out the line had just come undone right behind the fuse box under the hood.....open the hood and press the rear washer button if you hear the pump then its a problem with the line, if you don't hear the pump its an electrical issue
BBHOE
Birmingham
Ive got the same problem, the pump for the rear washer runs, but the fluid sprays out by the front fuse box....the only problem is, I can't find the other end of the line. Does anyone know where the line runs? does it run thru the A-pillar then thru the headliner? or underneath?
2005yukonxl
older thread but i just did this the other day. the hose is a rigid line with a rubber coupler just beside the fuse box. sounds like the same on the 07+ as it is on my 05. ours popped off (probally due to me messing around in there) and sprayed fluid out of the front half of the line all over the place. the other end is super easy to find, just follow the hard line thats visible alongside the fenderwell. it wont have gone far from where its supposed to be...its hard plastic and rigid.
austinr
2007 leaks in rear
I have a 2007 Yukon and it leaks in the headliner in the rear when i try to use it. Does anyone know how to get to it?
Administrator
by dropping the headliner....
Mrjvieira
