I had a set of hid's as my low beams in my 03 Tahoe, and never had a problem. They worked great until one of the ballast blew out. Ordered a brand new set, no biggie, until I tried installing them. I removed the stock bulbs and plugged in the hid's--nothing! There was power coming out of the factory harness, so it should've worked. I tried both sides with both not working. I plugged the stock bulbs back in and they worked as they should've. Plugged hid's back in, nothing again. I got the old hid ballast and bulb setup(I knew that it definitely worked)nothing again! WTF?!? Does anyone have any ideas or suggestions? I plugged the stock bulbs in and they still work fine. Anyone else have this issue?
