Denali XL aftermarket exhaust installation question?
hundhaus
Wyckoff NJ
Does anyone know if I can do this installation using jack stands or do I need the truck on a lift. I am not home and don't have the directions with me. I just got a Corsa exhaust for my Denali XL
Niz181
i did mine about 6 weeks ago without a lift or jack stands. it was a little tight and not too bad
Yukon John
SE florida
If you know someone that has a pair of ramps you can use would be the best. I have done it in the past on other vehicles and those things work great !!
harpsubb92
Just did the same install. Piece of cake on ramps and jack stands. You can always cut it in a few places to make it easier to take out. Putting the corsa in is easy ~30 min.
harpsubb92
Just did this install...very easy. You can cut the stock exhaust in a few places to make removal easier. Used ramps and jack stands. Corsa install is easy ~30 min.
firstcaddy
