Aftermarket tail lights
pnwdan
pnwdan
Cunning linguist
Arlington, WA
So are you gonna get leds up front to match?
I hadn't thought that far ahead. These only happened out of necessity since I just got done spending 3g dropping a new engine in it. What's everyone running in the front?
05Single
afraid of the dark
I have the drl delete and added another set of parking/turn signals. Then made the whole row led switchbabacks
Let me know if this video works ---->
I have Spyder headlights w/ CFL halos and HID in the low beam projectors and HIR in the high beams, Spyder corner lights with LED DRL's, andIMG_4736.JPG IMG_4738.JPG LED bulbs in the fogs. I have the 6 low/ 8 high mod where the DRL's and fogs are on anytime the headlights or park lights are on.
adventurenali92
Big Bear Lake, ca
Out of curiosity, are all LED tails direct plug and play? Or some,are and some are not? I have an aftermarket setup on my ride because the tails came,with the halos that I bought. Paid like $225 for the headlights and tails together figured why not. They look,good. Much better than stock. But thinking about doing LED and I want direct plug and play because I hate wires. Here's how he sits now. 0113161326a.jpg 0113161325.jpg
pnwdan
pnwdan
Cunning linguist
Arlington, WA
Out of curiosity, are all LED tails direct plug and play? Or some,are and some are not? I have an aftermarket setup on my ride because the tails came,with the halos that I bought. Paid like $225 for the headlights and tails together figured why not. They look,good. Much better than stock. But thinking about doing LED and I want direct plug and play because I hate wires. Here's how he sits now. View attachment 59362 View attachment 59363
The number one reason I went with the Spyder lights was that they are 100% plug and play. They contain the correct wiring and resistors so that your blinkers work correctly and you don't loose functions like cruise control. don't ask me why you loose it because I didn't look it up haha. I just read your will with some and so I went with the Spyders. They look good too
Countryboy07
I have Spyder headlights w/ CFL halos and HID in the low beam projectors and HIR in the high beams, Spyder corner lights with LED DRL's, andView attachment 59349 View attachment 59350 LED bulbs in the fogs. I have the 6 low/ 8 high mod where the DRL's and fogs are on anytime the headlights or park lights are on.
Man the fitment on those is terrible! Can you adjust them to make them fit better? They would look really good if they fit better.
Thanks for alerting me. I just checked and the driver side has a cracked mount so now I'm trying to epoxy it back together. Something must have hit it. Passenger side is fine though. And there are adjusters but I had them dialed in originally.
Phoenix2k9
