Jerome Nelson
- Joined
- Nov 22, 2021
- Posts
- 25
- Reaction score
- 19
Brief History:
This has been going on for years now. I made a post in 2021 and that helped solve some of the problems I was having! But now I've narrowed down a specific, reoccurring issue: fouling plugsReoccurring Issue:
About twice a month I'll get a P0172 — System Too Rich Bank 1.Rarely I'll also get a P0175 — System Too Rich Bank 2
The truck runs fine and I've replaced everything related to the code, so I clear the code.
After about 2 months, the truck doesn't accelerate properly. I also get mild vibration. No "missing" codes.
I check the plugs and the threads are about 50% "oily"/dirty. Once I clean them all the truck runs great again!
Tried Remedies:
Items replaced/cleaned so far over the last 2.5 years:• Replaced upstream 02 sensors (twice)
• Replaced MAP
• Replaced MAF (twice)
• Replaced engine coolant temperature sensor
• Replaced fuel pressure regulator
• Replaced Spark Plugs (2 years ago, Double Platinum Spark Plugs, instead of Iridium)
• Replaced Spark Plug Wires (2 years ago)
• Replaced Coils (all 8, 2 years ago)
• Replaced Fuel Injectors (1 year ago)
• Replaced Valve Cover Gaskets
• Cleaned Throttle Body (twice)
• Replaced Air Filter
• Techron Complete Fuel System Cleaner (x3 - once every 9 months)
• Seafoam (x4 - once every six months)
• Seafoam fuel additive (x2)
• Taking it to a Master Chevy/GMC mechanic and have him run diag and tests. (No conclusion.)
• Only use non-Ethanol fuel
• Added a catch can
• Reset the PCM. (disconnect battery, connect battery leads (sans battery), let sit for 1 hour)
NOTES:
It has an electronic Idle, so I couldn't clean the Idle Air Control Valve.
It also doesn't seem like it has any vacuum leaks.
We only drive it 2-3x week. ~10K miles a year
Central Florida
The only thing (that I know of) that I haven't tried is replacing or updating the PCM. (I don't believe it's ever been updated (2000).
Specs:
2000 Chevy Tahoe5.3
2WD
205K miles
4L60E 4-X Speed (rebuilt last year)
Questions:
1. Any idea what is causing the fouling spark plugs?!2. Any idea why I keep getting a P0172 code?
3. I used Double Platinum Spark Plugs, instead of Iridium. Is that causing a problem?!
I appreciate any feedback/guidance you can give!
