2003 yukon denali build
D
Duramax05blk
NH
a9f2a8a53fa934453ef72cf5ef3512dc.jpg2c863c249fd10548db56f30bbc1431bc.jpgc2efb5fe95121d97088b5e217c2cc04c.jpg
Fitting flares and adding some details. Bolts with solid washers suck...
D
Duramax05blk
NH
Only had a few minutes but was able to get the front flare bolted up and fitted
D
Duramax05blk
NH
Picked up a used grill haven’t given up on gmc hd grille but needs a lot of work. Got one taillight installed need to wire it still
D
Duramax05blk
NH
ec858dc654deda75215f74d0a8526401.jpg trying to get bushwhacker to warranty a flare before repairing, otherwise all the holes are drilled and nut inserts installed and flares ready for paint. making progress, getting anxious to start dialing in the suspension and motor
D
Duramax05blk
NH
Youngest won’t sleep so we are getting the reverse light/ blinker wired.
D
Duramax05blk
NH
Taillights are almost looking like they belong got the fogs mocked up the bucket is upside down on the bench.
D
Duramax05blk
NH
And now I wanna cry... had the hood slightly open to start aligning projects and garage door hinge touched the hood... hopefully, I can hide most of it with a repaint...
D
Duramax05blk
NH
Tires and wheels in order. They swapped those tires out for Ironman mts basically a knock off km2. The other ones the a manufacture could only locate two with no eta
Juju14
