Escalade side mirrors on a Tahoe LTZ!
tdriver113
Illinois
Yeah just did it for my girlfriend on her 2017 Yukon SLT and honestly didn't even think about year. Just bought a pair off eBay and some door panel clips and plugged em in and went. Only needed one clip this time.
My parents are wanting to do it on their Silverado and the mirror caps do look a little different between the Silverado and Tahoe but i was just assuming it would be the same wiring. Might have a look before buying another set of mirrors for them.
Tahoe and Silverado mirrors, post 2015 are not interchangeable.
T
TooMuchTxn
Houston, TX
Good to know thanks for the heads up I haven't seen their truck yet. Ill tell them about the tow-mirrors maybe.
Heidencbr
I checked the mirror connectors for the 2015-2017 Tahoe and Escalade on the GMSi site and the pin outs are the same. So in theory you should be able to source one from 2015-2017.
Do you have access to the green camera connector pinout? I am in the process of hooking the esky cameras up on on my Denali. I got the esky Mirrors and installed an MVI interface and am just needing the pinout so I can splice to the rca on the interface.
DenaliBQ
The cadi mirrors I bought had oem cameras yes. The kit from MVI, I had to buy the side cameras for the wiring and motherboard that goes behind head unit. Even though I didn't use the MVI cameras I needed the other parts that came with their kit to make the Escalade OEM mirrors work.
Can you show us some pictures of what your screen looks like working i am curious being the cameras are not blind spot cameras but 360 cameras
BEIS
Alright, so I sourced a new OEM Escalade passenger mirror assembly with Blind Spot, Puddle Light, camera, etc.
Upon inspection, the puddle light lens seemed to be a little loose. Is this normal? It can't rotate, but it can move a little. Before I return this, would like to get other's experiences. Thanks in advance!
cmatt
I checked both of mine and there is some play. I think it would probably be deemed within tolerances.
Hattie2879
I don't know how to post pics on here, but I finally got my mirrors changed out. Didn't upgrade the harness or anything fancy, basically just swapped my Tahoe mirrors with Escalade mirrors.
Thanks for all your help guys! I love the bigger mirrors already!!
16yukon
