Erickk120
- Joined
- Mar 19, 2018
- Posts
- 384
- Reaction score
- 213
Hello guys first time here, came over from ls1tech I have an 04 tahoe with 214k miles I changed my oil pan gasket today and noticed There was coolant in the top of the tranny oil pan front area, note this is only the passenger side, it gets there through the outside transmission oil dipstick tube, the tube itself is dried in the top engine bay area, but gets wet somewhere down the line and carries the coolant to the tranny oil pan top area. So, my question is what is in the back of the engine block/heads that could leak? I was suspecting maybe a freeze plug in the heads or a coolant pipe in the back? or are those just blocked and capped at the back in these engines? I just wanted your 2 cents if any of you have had a similar experience or seen this before. Pic not related that's me stripping my oil pump pick up tube bolt, I got that taken care of. things do happen.
I'm looking forward to learn a lot about this gen of suv's in this forums!
Thanks in advance
Thanks in advance
