PG01
Up here to the right
First day off of work in 12-14 days. Wife’s cousins are here from texas but the plan today is to go over the hoe, top to bottom and ready her up for my yearly trip to Florida, over 3000 mile round trip, (to wish @THE YETI a Happy Birthday in person and maybe, just maybe go to some parade he attends that he cant stop talking about and brags that he is the grand marshal every year since its inception... i dont know, still on the fence about the parade)
Nevertheless, i will go over the tahoe, change the oil again (i like doing it right before i leave and right when i get home) trans fluid, check fluid levels, grease eerythin, tire pressures, pull down spareto check functionality, and then clean this dirty hoe, top to bottom... then ill go over my trailer. Busy few days...
I used to do those straight through runs, best time was 17 hours but usually 20-24. Nowadays we spend the night in Lumberton, North Carolina.
Wave to us when you pass through Port Saint Lucie. Doing any fishing? The dolphin and footballs (blackfin tuna) should be starting to run.
PG01
Yeah, we have to stop 9000x for the girls to pee... 20-24 depending on how may pee/gas stops. Not a big fisherman but the houses we rent are on man made canals and i go get some live shrimp and some k mart fishing poles and catch whatever makes it way up the canal. I have to bait everyones hook because no one will touch live shrimp and if they catch something i have to unhook because again, nobody can touch..
Same here, all girls. I'm the one stopping every 80 miles; diabetes. Whatever swims in the ocean can find its way up those canals. I've seen Bull Sharks 20 miles inland and spotted eagle rays way back in the coastal canals to name a few. Enjoy! We're planning to wet some lines too soon.
randeez
south florida
Much needed lube up:
Changed the oil/filter
Dexos VI in the transfer case
Redline 75w-90 rear axle fluid, fluid looked pretty clean but magnet had a good bit of metal sludge on it, also has magnetic fill plug. gear pattern looked good.
and put on and adjusted spohn panhard bar, noisey as hell i'll prob take it back off another day and lube the hell out of the poly bushings
Front is a little low now to change that diff oil, it'll be at shop later this week for some new tires I'll change it there.
Phoenix2k9
