05 Nali XL driver door power prob
FreeIndeed
I started having 2 problems, which may actually be one, I'm not sure:
- I intermittently lose power to the driver door switches
- Interior lights stay on and truck doesn't recognize the door is closed
I read that the BCM senses the door is clos3ed through the door latch. IS that right? Any help or things I should check? I have the door torn apart now...
HiHoeSilver
Away!
Chicago
Check out @M1Gunner write up for the door switch.
FreeIndeed
FreeIndeed
I had read to check the orange power wire that comes into the drive door module (in the front connector) for power so I did that tonight. I have power coming through to the DDM. I really didn't think the DDM would be bad after replacing it in the last few years, but maybe it is.
FreeIndeed
FreeIndeed
RESOLVED. To help others here's what the dealer found: I had a broken power wire coming through the door into the DDM. Apparently there are 2 power leads that come into the DDM. I was so close..... ANyway, fixed all power probs, door chime etc work.
