I recently had the driver door window switch panel replaced on my 11 Tahoe and ever since then the radio and dash lights won't go off when opening the drivers door. They go off eventually but not like they should. There was nothing wrong with the switch that was replaced but the dealer I got my Tahoe from agreed to fix the drivers door mirror not tilting. I didn't figure that would fix the problem and if I knew it would be causing the change I've had since I would've had em put the old one back on. I'm going to call and have them put the old one back on Monday unless there is a fix someone knows of.
