Crazycrew's 2013 Denali CCSB Build Thread
jerryjoe28
That Guy
cabot AR
They have em readily available. Not sure of costs though. Haven't really thought of it until Cody mentioned it
I like the AirLift 25870 as it seems really simple to use but @yates ™ pointed out that it doesn't have dual path so u couldn't do much with an unlevel load. think the dual path kit is the AirLift 72000
yates ™
Resident Apple hater
Iowa
I believe the dual path uses a smaller compressor than the single for reasons I would never be able to figure out but should be fine for helper bag systems.
jerryjoe28
That Guy
cabot AR
well depending on how the next few months go I will be going that direction ........ or something much better lol
yates ™
Iowa
Absolute worst case you should be able to run a small VIAIR instead of the original pump.
C
crazycrew
Vacherie, LA
Any of you guys ever install coil relocators? WTF? After removing the factory "bucket" how the hell do you get the coil relocator to go over the ring that's made into the strut, or does that factory ring come off too?
madmax442
