Matt's Yukon XL 2500 (Giant Silver Unicorn) Build
Matt_
Matt_
Thanks guys!
Here's an update to the trimming.
Pro Comp Brackets 90-3575 and 90-3576 had to be modified to eliminate rubbing. Not a big deal, I just cut off all excess material and mounted with one upper & one lower bolt. Then some trimming and heating/forming of the liner.... not too bad. These brackets were definitely a life saver!!
Really.... for taking 1.5" off the bumper I think it came out pretty damn good. Only ones that'll notice are other GM owners who have been through our hell of trying to fit bigger tires lol
Matt_
Matt_
Here are the in-process pictures from installing blocks, shocks, and 2" steel wheel spacers on the rear to finish the job earlier today.
I still need to do something with the brake line brackets, or put limiting straps on... or both.
Also don't have the final lift numbers yet, but I'm worried it might be perfectly level with the 3" block. Not sure I want to lower the front anymore since I really have nothing else to trim. If i need to bring the rear up another inch I'll be looking into Deaver spring packs since I don't want to run a taller block.
Matt_
Matt_
In general I haven't been much of a fan of removing the door molding from the GMT900 trucks because the body lacks transition curves like the GMT800, so removing them made them look like billboards (IMO) with huge open space that would draw the eye....
......but, now that the truck is lifed, that 'huge space' isn't so huge compared to the overall area anymore. I'm thinking they're coming off during the next sunny day....
Please don't make fun of my Microsoft Paint [lack of] skills :crazy:
niely
Fort Wayne, IN
How do you like the AMP Research boards? I've been looking at those for a while. Looks fairly easy to install. Like you said, more moving parts etc is my only concern. I also have 4 kids! We are a rare breed
madmax442
