Adding heated seats to 2016
motorswin
Hey everyone, I am adding heating elements to my stock cloth seats and I need some help. Does anyone know where I can tap into the vehicle's wiring to have a "ignition on" wire. I don't want a constant hot incase someone leaves the heater on. I want it to be disabled when the ignition is not turned on.
Thank you
GTNator
Thank you
That’s cool, I didn’t know you could do that with clothe seats.
Potch
Phoenix
I'm about to install heated seats on my 2002 with cloth seats. Just waiting on a few things to be delivered later this week. I plan on tapping the power window fuse so they shut off when the vehicle isn't running.
motorswin
motorswin
anyone have any suggestions on where to tap into that wire on a 2016? Or a different wire?
AngelXL
Looks like is negative trigger so you might need a relay. Sirens are + trigger with a ground to metal.
AngelXL
This for a 17 Yukon. Don' know if is the same. Test before connecting.
firedog9518
