I bought a used set of the newer design valve covers with the built-in PCV system that replaces the old ball style. Only paid about $40 for the set, and $7 for the VHT crinkle paint, and baked them in the oven so they're high heat ready. The Fel-Pro gasket set was $21 but I probably needed to replace those anyway on my old set. So pretty cheap considering I've seen sets on EBay for $120-$ 140 that are powdercoated used covers and don't look as nice.
HiHoeSilver
Away!
Chicago
View attachment 183634 View attachment 183635 View attachment 183636
They're so fast.... Nice job!
05Single
afraid of the dark
Nice score on valve covers and the cruze rally sport
Should at least get her tint and hids heads/fogs so she can see during the dark winter nights.
bottomline2000
Dallas, TX
Nice, what does the underside of the PCV side look like?
Sent from my SAMSUNG-SM-T377A using Tapatalk
What year did they come out with those?
95escahoe
I think 04 was the first year, when I first got the Caddy I figured I'd do the PCV valve not knowing when it was done last and found out it's not replaceable, there's and updated driver side valve cover after this one they changed the PCV valve inlet on the inside of the valve cover something to do with oil consumption
That's correct from what I've read, 04, and yes to help with oil consumption, so hopefully I can run without a catchcan since I heard you shouldn't run one with a blower. But my throttle body has stayed spotless since I installed the blower anyway so I might not have a problem.
ylwdogs
