***lengthy post just forewarned!! Lol***
Hey all! So we're discussing my 99 obs gmc k1500 burban with the 5.7 4wd sle. Had the cat issue "taken care of"ie removed till i can afford a full exhaust with high flow cats, because i was told that they were the cause of my catalyst efficiency below threshold bank 1 and 2 codes and the reason why its boging down backfiring and acting crazy for the first 30 seconds when I go to drive after work in the morning or anytime it sits for a while. After i feather the gas a bit it goes away and runs fine. We Changed the o2 sensors about 6000 miles ago when i first bought it along with intake gaskets, t stat, belt, transmission issues fixed u joints,shocks and other things. This was all done at the chevy dealership I worked at.
So i took it to the chevy dealership in my new town to get it diagnosed and they found 5 codes. 4 of the catalyst efficiency codes and one dealing with the fuel system running lean. Vac leaks is the first thing that came to mind said the tech So they hooked up things to check fuel pressures, checked plugs wires vac lines etc. everything came back normal. They used 1/4 tank of gas driving it today lol. So they called and said they couldn't figure it out so they took it to the gmc dealership and had their tech check it out and nothing different. They reproduced the issue but no new codes show up when it happens or anything to alert them of whats going on.
So They want to just throw a bunch of parts at it and see what happens. The parts include a upgraded fuel spider conversion, fuel pump and fuel filter(the fuel filter was done 6k ago) plugs wires and cap or what ever i have and checking and removing every vac line and replacing as needed and all new sensors ie tpms iac mass air flow etc. and thats along with a brake booster and master cylinder for the brakes because of the hissing noise it has and that separate issue. They said if they replace all of this and and it still does it then ill be looking at a engine tear down to check for cracked heads and other engine related things. Even though i don't think i have any symptoms that would justify that.
The cost is in the thousands and i cant afford that even at non dealership mechanic rates nor can i do a lot the work my self due to lack of tools work schedules etc. Does anyone have any idea or experience with this issue? Its getting bothersome and want to get this thing mechanical good but its one thing after another. My pocket book might not be able to afford this thing if things keep going wrong. And of course i cant get it to act up to post a video either. Go figure. Sorry if this is all over the board tried to give as much info as possible.
