Back N Black
Houma, LA
Well, technically yesterday, BUT . . .
I re-adjusted the timing. It should be correct now, but I need to run it on a computer, to check my codes and check my timing.
Remedy
Replaced brake light circuit board on back right and new windshield wipers. It's the little things
Remedy
Idler pulley, installing the wrong belt, thanks Amazon, Installing the right belt, new discs and pads!
Ready for a road trip!
CO-Tahoe
Well this weekend I fixed my gauge issues, fixed my transmission shift problem, replaced the broken door handle, fixed the busted grill , installed the brush guard, shampooed the interior, and did the wheel speed sensors on my 2000 Z71 Tahoe.
Nice productive weekend.
Back N Black
Houma, LA
I painted the wheel wells and frame black. Looks good. And changed the starter . And the fuel filter. She starts and runs strong
:pics-stfu: I need to paint my wheel wells and frame! Looks so much better that old rusty orange. I have done this on several of my vehicles.:waytogo:
Creese99
Ocala Florida
What did you do to your gauges and transmission?
CO-Tahoe
Changed the shift solinoids amd the VSS, also ran down the harness and found a diconnected connector. not sure what all did it it but now it shifts like a new rig. The cluster I ended up just going down to the pull and pay and searched for one with the same mileage. finally found one and it worked for fixing all the gauges exxept the fuel gauge. So I have a new fuel pump/sending unit and wil be tackling that one this weekend.
