cardude2000
- Joined
- Nov 12, 2015
- Posts
- 2,931
- Reaction score
- 1,036
Probably need to probe wires running to light connection. Once I find time I'll take a look. It might be simple to replace, however, I don't want the light on 24/7 with truck running. I havent really checkes but I believe This is how they are currently wired...more like ambient lighting.
You're correct. I just plugged an led into the plug (disconnected the existing light connector) and it worked...but it stays on once the dome lights go on. Would need to switch the wire at the fuse box to match the dome light. Not sure which wire goes where.
