Switchback LED turn signals
kingkon
Miami, FL
I am looking to replace the front turn signal bulbs with switchback LEDs. I was looking at a set on eBay that comes with the resistors and connectors. I was thinking of going that route, or replacing the turn signal relay and not doing the resistors. Has anyone made these work?
Bulbs and resistors:
https://www.ebay.com/itm/322073573441
Or flasher relay and bulbs:
https://www.ebay.com/itm/282083280030
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I've done the bulbs and resistor route. This requires you to cut and splice the resistors inline with the turn signal. Relay, just replace relay, no cutting of wires involved
W8TVI
Traverse City, MI
I used the bulbs and new flasher relay option on my 2000 Yukon XL, and when my dad got his LED turn signal assemblies, we also used the new turn signal relay.
kingkon
kingkon
Miami, FL
I just received the switchback bulbs and put them on. With the lights in the white turns on fine. But with the turn signal, the white stays on and the orange flashes. Haven't received the led flasher yet, don't know if that will make a difference or if the led flasher is just for the hyper flashing. These are the ones I got:
https://www.ebay.com/itm/222425553161
W8TVI
Traverse City, MI
Some of the cheaper ones don't turn off the white light, and just flash the yellow over top, the better ones alternate the white and yellow, and the best ones switch off the white while the yellow flashes on and off.
http://a.co/2zJmgaC <-- I found this one on amazon, but you will pay $25 a pair for them. They flash "amber-off-amber-off" for the turn signal.
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
willie110hh
