Rocker Switches Install
Cattivo
The Concrete Jungle
I am doing a Kenwood ddx393 double din when taxes come in. I want something clean and sleek. the most I will have is led pods in the grill and maybe maybe a led bar so the 2 in the cubby is perfect. a couple gauges I will be set. I am also taking one of the cig lighters out for my aux/USB in for the ddx393. also cutting the back out for the cubby ducked! all I have is a jig saw and band saw, but I will be getting a drimmel in the near future(tomorrow)
Did you ever get yours finished?
05Zsvntyfun
Update: I cut up the lower portion of the dash with my dremel and installed the abs plastic with black caulk(bad idea) I'm going to try and clean out the caulk and glue it in instead then wrap it in carbon fiber.
I just need to figure out where I want everything mounted (3- 52mm gauges 4- rocker switches 1 or 2 USB ports) definitely don't feel like cutting and shaping another large piece of the abs plastic to fit...still not sure what to do with the cubby hole, I already cut that piece out as well...just needs to be installed
Disregard the terrible music lol
I know you're probably already done or way too dedicated to what you're doing. But I got this switch panel and it looks great. Replaces one of the cigarette lighters with a clean dual USB, has 4 switch cutouts for whatever, and maintains the main cigarette lighter. I think it's worth the money. http://longhornfabshop.com/longhorn...anel-with-dual-usb-charger-4-switches-201000/
Cattivo
The Concrete Jungle
I have a 4 gang switch panel I still need to cut out above the 2'' gauges... I'm still not sure if I want to mount the USB's next to the rocker switches or up in the small cubby space. That switch panel in the link would of been great if I didn't cut up the trim piece lol
kracker456
