Low cold start oil pressure
lkrasner
Noticed that my oil pressure has seemed a little low in the cold this winter. Sits around 30-35 at idle, climbs to maybe 45 driving, but doesn't settle in to 50-60 like Id expect until the engine fully warms up.
Is this something I should have serious concern about? It feels like if runs just fine. Doesn't burn much oil. If f I check after about 5k, it's usually down a bit less than a quart. That's nothing new, been happening for years from various small leaks.
5.3 with 298K miles. I run Mobil 1 high mileage full synthetic, 10w30 in the summer, 5w30 in the winter (5w30 in it right now). Mobil 1 high capacity filter as well. Usually change every 6k, about 5 since the last change right now.
rockola1971
Indiana (formerly IL)
Agreed. Oil pressure is fine. Take the money you've been saving up for an oil pump remove and replace job and use it to go buy a new gun!
YukonandtheHOE
I learned about this with my 350 Olds Rocket, sure a guy could pull it down and redo the clearances to have 40 PSI all the time but "if it ain't broke don't fix it"
L
lkrasner
The part that scared me is that close after startup, the pressure would actually drop if I put my foot down. Not down to 0 or anything, but it certainly didn't rise like normal. Now, the gauge has done the bouncing thing at idle for nearly the cars entire life, so I suppose this could be a sensor issue
YukonandtheHOE
Yup try a sensor, if its the same as it is now, the cam, rod or main bearings are just getting wore down, especially with cold starts. only If you have really high oil pressure or >10 you need to worrie
rockola1971
Also check for corrosion or loose connection of the wiring harness at the sensor.
Tahoe Belgium
