I want to delete my muffler on my 5.3 hoe, does anyone have a sound clip of what i have in store?
popo8
the Flowmaster Super 10 dual in dual out will only cost me 150 bux, will your idea produce a similar sound and cost the same or less?
My idea would cost less than 30 bucks for a manual cutout if u can do it urself.
Ur the one that wanted straight pipe... no mention of a flowmaster in the beginning.
LTXtech.com IS my drug...
OWNER/ADMIN
bacin87
bacin87
San Francisco, Ca
OWNER/ADMIN
As I read though peoples post they said it would sound horrible as a straight pipe so I went back to my original idea. I was asking you if I went with your idea would it have a similar sound and price. I am asking you because I dont know and I am pooling ideas.
popo8
I think it would sound like poop as well... but since that WAS what u wanted, I was giving u a way to achieve the results that u had wanted and not be stuck with it.
OWNER/ADMIN
05Single
afraid of the dark
Cut outs are cheap... if electric ones are 2 expensive... do manual cutouts.
OWNER/ADMIN
How reliable are the e cutouts? Just my luck it will seize open miles away from home lol
Christoph559
I did it on my 07. Cut muffler out and left resonator on. I think it sounds pretty good at WOT but sounds like our boat at idle 4 cylinder mode is super annoying! So if around town I'll drop it in 3rd. I'll try and get a sound clip
Brian Wilson
Electric cutouts are good. In my experiance the machanical cutouts are just as unreliable due to the cable rusting or having sharp angles in it. And every mechanical one i heard rattles and sounds like an intermittently leaking exhaust. If going electric youwill need to find a good one and spend a few extra dollars for quality. But even a cutout stuck open will be less permanent than a straight pipe. Just pull it out and clean it and you are good to go. A straight pipe on a 5.3 with or without resonator doesn't give you a muscle car sound. In my opinion it sounds loud and nothing more. 0 masculinity in the tone especially with a stock cam. Most people who try straight pipes really just want the muscle car tone and lope. Which you will not get. Just an awful tone that is so loud you have to drive with your head down in embarrassment so nobody sees you. And forget about reving at a stoplight.
Phoenix2k9
