Has anyone put a subwoofer setup in the rear?
abond2014
Hello everyone,
Just curious if anyone put a subwoofer system in the back of there trucks and if so howd it come out?
Pops McGee
NJ
Hello, not me yet, but i did always plan on removing the third row to clear up space to add a subwoofer box in that space.
I have no plans to ever use the third row for passengers. I've had my 2016 LT for 7 months and have never used these seats. They're basically taking up usable space. I figure its a good 8-10 inches or so of height i could gain to have a custom built sub box sit down in space where these seats are now and fold flat. This way it would not stick up much above the back floor. I only plan on using 8" or 10" subs in a custom stealth box
Would welcome anyones thoughts?
Thank you
abond2014
abond2014
Thank you
I am the same way, I dont use the third row so possible a setup behind the second row would be ideal!
thindiesel
Baltimore MD.
I have.... are you looking to set it up with factory or after market radio? if factory I would recommend an Audio Control piece called LC2i.... I run a car audio co. in MD, so if you have any questions please feel free to ask.... My system sounds great....
vishnu619
Did you run your amp power from the front? I thought I saw someone tap the power in the rear by the fuse panel but could not find a write up on it. Thanks.
Sent from my SM-G935T using Tapatalk
abond2014
abond2014
im gonna run the stock radio for mine but add a sub or two for some punch. Post some pictures of your set up
Exactly what fuse panel do you have in the rear?
Edit: just realized this in the 2015+ section...nevermind, I have no clue about these trucks!!
abond2014
abond2014
im very curious to see if any of you have done so and how the setup for it is, Thanks!
toi
i always thought about adding a ultra slim woofer where the back storage companrtment goes. is that even possible you think ? maybe even using the compartment itself.
i drive a suburban.
DefiantOne
