Service Ride Control???
DenaliAK
Colder than you
Alaska
Two weeks into owning an '03 Denali here, and I am now getting a message to "service ride control." I'm not even sure what that means, but assume it has something to do with the air ride suspension. Any ideas? Haven't done anything to the truck since we got it, and it's pretty stock. I don't have money left to fix anything expensive....lol
denalianyone
NYBlackLade08
New York
check your air ride compressor, electrical wiring to shock, and air adjust linkages
Mac
NY
It means your rear shocks has a leak and the compressor kept pumping it until it died.(Hence Service ride control) So, now you have to buy rear shocks and a compressor....Easy job but expensive parts....good luck..
DenaliAK
DenaliAK
Colder than you
Alaska
That is NOT what I wanted to hear....lol.
I've only had it for two weeks. :emotions122:
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
i get that occassionally...I turn the truck off and back on and it's gone. it usually happens to me when i start the truck and quickly jump in reverse. not sure if i'm activating a sensor or something, but my compressor functions properly.
MikeTheApeman
The armpit of America - New Joisey
Isn't there a way to bypass the ride control and basically turn it into a standard suspension in the rear? Not saying the OP would want to do that, but might be a cheaper way out until the cash is available to fix the compressor.
BlackDenali
Roof Rack ****
Boca Raton, Florida
Does your compressor make any noise when you start your truck???
If it does then your compressor is fine, next check your shocks when your compressor turns on and listen for any hissing or air leaks!
Anthony
2004 Tahoe LT (MA)
Westen MA
I think I remember 2 or 3 threads on people trying to do this, but were unsuccessful in locating the parts :(
graphicideas1
I did the swap. I purchased 2 Monroe shocks and installed 3.9 ohm 25watt resistors. ALl works fine!!!!!!!!!!!!!
All you need to kill the error message is the resistors, you can buy shocks at anytime after you confirm the message is gone. One thing i noticed if you remove the compressor , even with the resistors, you will get that message. I dont know how the bcm knows i have the compressor plugged in because it does not work. You must keep the compressor plugged in!
kracker456
