2012 Tahoe won't start
Billeickmann
Motor City
My Tahoe has 55,000 miles and has been very reliable. Last week, I got the check engine light, but it continued to run properly on my way home. Just a few miles. Next start, it ran very rough and stalled. Check engine light was still on. I tried cleaning the MAF, as it had never been done and put in a new air filter. Now, she cranks just fine, but does not even kick. No hint of firing. I pulled a spark plug boot and it sparked a plug when cranked. Not a big spark, but it jumped the gap. I then tried some starting fluid and nothing. Three tries and just a little cough. Could it be a weak spark?
I next bought a code reader off Amazon. It shows the vehicle VIN, but no codes. I tried cranking with the code reader on and still no code. The check engine light is still on. Repeated several times.
I bought the truck new Jan. 2013 and it has had no engine work, so maybe I am overdue. Any suggestions please?
check to be sure you have fuel pressure
wsteele
If you have a CEL and your scanner isn't displaying a code, I would maybe consider a problem with the code scanner first.
Multnomah Falls
Military
Code scanner or operator problem. What color was the "weak" spark you saw? Orange or blue? Need fuel pressure reading. Age of tune related components? Original? At 55k miles I would assume they are.
Bill, you have to get those codes, otherwise you're just guessing and wasting time and maybe money. Seems like a fuel problem to me but I haven't seen the codes!
Billeickmann
Billeickmann
Motor City
OK. I went out to my truck to try the code reader again and she started. There was no check engine light, but she did run rough. It slowly became normal after a minute. I tried the code reader and I got P0172, system too rich bank 1 and P0175 system too rich bank 2.
Billeickmann
Billeickmann
Motor City
Shut her off and let her cool. Started again and got the same two codes again. Yes, all of the engine is original. I have only done tires, brakes, oil, battery, and filters.
wsteele
Is your truck a flex fuel version?
wsteele
Also, if you could determine if your scan tool can do live data display, that is probably going to be helpful down the road (most do).
waiteben84
