I think I might go this route. I have all the oem parts, but I haven't found anyone local that can program my pcm for the fans. Would it be possible to hook the aftermarket thermostatic switch to the oem wiring and the fans?if you do find a full kit, you also need to re program the pcm so the fans work.
i did aftermarket fans on my 03 back in the day, i used a thermostatic probe in the rad fins to control the fans.
So the green ac wire to a fan wire or to a relay? I've never used relays wiring things. Never had to tho--maybe lol.that im not sure. i went full aftermarket, used a fog light kit and another relay. then used the switch to turn them off manually if need be. master on off if you will.
this is all i can find for pics. i know i have more of the relays and termal temp thing. i ditched the whole shroud too, (greasing the front end became 1000 X easier too.) temps were a degree cooler vs the clutch fan, and the ac was never colder. that was the other thing. had to run a wire to the green ac wire on its plug at the compressor to command the fans on when the ac was on.
I def want to do that. My gf drives it mostly, and I know she'd forget to turn them on.that wire went to the thermal temp probe box, it also had a dial on it to set what temp the fans came on.
the thermostat i had burnt up a year later, ended up running them on the switch only for the next 5 years. as long as they are on the ac still works as it should. engine still ran at 210. id turn em off in winter for its warm up, got heat faster with no fans, once moving you dont really even need em. i played the on off game.
