Chase's (BigBearDenali) cluster upgrade
Bombsquad85
Northern VA
Do you use solid wire for the strips?
I used 24 gauge stranded wire.
https://www.amazon.com/gp/aw/d/B06XWN1NL4?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
But I have used solid wire in the past, I ripped some solid wire out of an old Cat-5 network cable. You just have to be careful that the solid wire will not flex and end up breaking. So inside the cluster if should be just fine.
I just redid mine just now with LED strips. I wish I did this initially! @Bigbeardenali1992 not to hijack your thread but I did just the same set up for LEDs as @ScottyBoy and it came out great! Just with stock guage faces
Nice work @ScottyBoy as usual. I was lucky that my 02 had the twist in bulbs so converting to LED was easy but at the same time the rest of the upgrades for the 02's are limited like the gauge overlays, etc.
04Huck
"I'd rather be lucky than good"
Buford, Ga
It does look really good. Only thing is that i can see all the idiot lights without them being lit up...brights, cel, awd, tire, o/d...etc.... blinker cutout would be fine but why didnt they just blank out the rest? maybe white overlay is too thick for light to shine thru... i like the white with blue tho... looks good. Nice work Scott, good choice Chase....
My thoughts as well. I LOVE the white with blue needles and the chrome trim rings, just hate being able to see all the idiot lights. That part should be black like factory. Wonder how hard it would be to blend the two....
S
ScottyBoy
Shreveport, La
The idiot lights are only on because I was bench testing the cluster. That's the same lights that are lit up with the IGN switch on but the engine not running. With the engine running, those lights will be off.
PG01
Up here to the right
I dudnt mean they were on, you can see the outline.... at least it didn’t look like they were on
No the lights aren't on, the overlay is different like that. All those can be seen even when the lights are off. That's something I noticed when I bought a cluster with a white Esky overlay and I didn't care for it either. I ended up sending that cluster back and that was one of the reasons why. I thought it was just the place I bought it from but it seems maybe they're all like that?
PG01
Right exactly wut im saying... @Sasquatch ’s look good....
Not that these dont look good but that just dont jive wit me
Shaw520
Yes,..understandable... The fact that you can read all the signals without lighting IS the difference,....apparantly some like it and some dont,.. I do.
chevy529
N.E British Columbia
That looks really good! Nice job!
Hesitant to ask but is the X27 more reliable\accurate or what is available today?
Ignore if the question is inappropriate here.
16yukon
