2013 Avalanche...LMG 5.3 to L96 6.0 (Pics)
01FormulaTA
01FormulaTA
Lookin good man, was talking to you over on PT.net - looks like you finally decided on which engine? :lol:
Yes sir!....how are you liking your new setup? I saw you posted some numbers, 403 rwhp...not too shabby!
Quick question, when you had it on the dyno did you have any problems with your stock driveshaft? Any plans on getting a custom driveshaft?
Edit: Now I see you also posted some mid 13 second time slips, nice! :driver:
randeez
south florida
403 dyno was sketchy af :lol: 4th gear pull. but i am also short wheel base
truck has since been tuned on/off a different awd dyno (they used 3rd gear pulls)
new rear suspension seems to be paying off, times keep dropping and i can dial it back during the week for cruising. last few times at track have been crowded so not many chances to try out new settings/launches.
01FormulaTA
01FormulaTA
a little update...
LS3 Rockers w Straub Trunion Bushings
Circle D Billet Flywheel w ARP Bolts...
On the Home Stretch....
randeez
south florida
did you do the trunion upgrade yourself? i completely missed doing them while i was in there. I may grab another set of oems and get them set up just to sway
01FormulaTA
01FormulaTA
The Trunion upgrade was a pain in the A$$, but its worth it for cheap insurance and piece of mind...its just time consuming and tedious mostly....I did it at my kitchen table using only a vice, snap ring pliers and the Summit Trunion Tool (SME-906011), some videos show using an arbor press as well but I was able to get away with just the vice....
After a couple boring hours...
Much better than the factory needle bearings...
None of you little bastards are gonna end up in my oil pan!
2DoeProjectHoe
