Escalade Roof Rack and How to
KBones
Ive finally got them painted and installed. Had them color matched and Cleared.
picture.php
Sanded and ready for paint
picture.php
picture.php
Freshly painted
picture.php
picture.php
Fully assembled.
Ok now the how to.
there are 5 bolts per side. 2 on the front end, 2 on the rear and one in the middle. They are a T25 torx Bit. Once unbolted, the whole Rail is Ready to come off. Save all the bolts, your going to reuse them. Repeat for other side.
picture.php
picture.php
picture.php
picture.php
Now is a good time to Clean the area under the old roof rack. I ended up washing and Buffing those areas. Some of the outlines can still be seen but its on top and im not to worried about it.
Now for the install.
The endcaps on the esky racks are held in by a clip. Pry up on them and set them aside.
picture.php
There is a anchor nut that you need to install. I had ordered them from Gmpartsdirect.com and they got me in shipping. Here is the part number so maybe you can get them from the dealer cheaper. I paid like 30 bucks for 2 and shipping.
picture.php
Take one of the Bolts you removed from the original Racks and put in through the nut and install on to the middle Hole.
Take the rack and install it over the anchor nut and slide it back to lock the center into place and match the Mounting holes. Install the 2 bolts for the front and rear. Repeat for the other side
picture.php
picture.php
picture.php
(thats Right Im Rocking a Pink Snapon Driver Gun that i bought for the wife.)
picture.php
If you have cross bars, install them.
picture.php
Install all the end caps and relax. Your done.
picture.php
picture.php
I just noticed...your rack seems to be on backwards..
lonestar24
Just installed the side rails. Even with the center anchor nut the rail sticks up just slightly from the roof. Is this normal? Way to remedy it?
full
KBones
I had that issue also. I just removed that center peg and ground off some of it from the bottom side and re-installed it and test fitted. I had to remove them one more time to take a little more off and they fit nice and snug now. They just seemed too tall.
full
crazycrew
Vacherie, LA
I may have one for sale tomorrow, off my burb if anyone is interested. Mocha steel metallic. I would really prefer not to have to ship it.
qcon
Huntsville, AL
30250DB0-AECB-4C3F-A8C6-7440D4CB3E91.jpeg Is there a trick to get the nose of the front end caps to sit down flush onto the gasket?
mitchievu
