- Joined
- Jan 3, 2011
- Posts
- 49,909
- Reaction score
- 15,453
good job, uncle willie
Not in a day or two. Still trying to fix the ones I have LOL>What else is new ??? Have you bought any new toys ?
Well, you got to keep your beard on your face, so I guess it was a successful day! Job well done.IT was broken worse than I suspected.
At 845 headed down to TIm's. Right off the bat we had a problem. Steph ran the battery dead with the hazard lights last night. Tim pulled his big e350 van over and jumped it off The truck would not move at all. Since it had a tire chock under the back tire it wasn't going anywhere.
He went to fire up his little John Deere. It had a dead battery. However the Power King next to it had a new one. We jumpstarted the JD and he pushed the truck off the chock.
He has his forklift attachment on the loader. when ht pushed the truck up on the lift the hitch ball got hung on the loader. IT took some doing to get the pin out of the hitch to get it out.
We got started pulling it apart.
We had things well underway when Steph's alarm went off. She had to take Emily to work. I told her to go get the parts on the way back. I don't think she was out of the driveway good when we got the clutch out.
Tim and I sat and chewed the fat for a bit. Then he got a call. One of his customers had the front end loader fall off their TC30.
Tim just traded for a beautiful 65 Ford dump truck. We took it over to the guys property. Turns out the problem was poor maintenance. 6 of 8 bolts that hold the loader to the front arm were gone. We got it lifted back into place and told him what bolts to buy.
We got back to Tim's shop and waited.
Eventually, Steph came back. She had all but two parts and had to go up to Lincolnton to get them. While she did that we installed the clutch, and every thing else we had parts for.
She got back and we got things buttoned up. My back was screaming. I almost couldn't get out from under the lift.
Steph took it for a test drive. She came back and it was idling about 1800 rpm. She also said it had no brakes. I opened the hood and nearly got my beard sucked off my face, the brake booster line was off. Both problems solved.
When we got home it was time for Steph to go get Emily. I waited for Heath to get off the bus. After he did I got in the shower. Now I am sitting here, hurting like mad, barely able to keep my eyes open. How does a simple clutch job wear you out so much.
