tRidiot
- Joined
- Dec 21, 2011
- Posts
- 363
- Reaction score
- 283
Dude this needs it's own thread
What does?
There's plenty of space in that trim panel.
Running a 15k watt burp amplifier is no joke. Been a while since I heard my eyes go blurry. Does it do hair tricks?
Gents, this is great, but you have to remember some basics.
1. When you do this, you have to replace all of the batteries at the same time, and they have to all be the same.
No, that's only true if you are hooking up batteries in series or if they will be connected to each other all the time (i.e. with no isolator.) If you're running an isolator like I am you can have different batteries at each end (obviously of the same voltage) although it helps if they're both the same type (FLA, AGM, gel) since each of these battery types has a different charging profile.
In my case, my starter battery is a Deka 55ah AGM and my house battery is a 68ah X2 (which I think is a NorthStar, but not sure) also an AGM. The only time my batteries are connected is when the ignition is on, once the ignition is off my house battery is isolated from the starter battery. That lets me run a refrigerator (Truckfridge TF-41, 41 quart) in my truck without having to worry about discharging the starter battery and being stuck.
On our trailer, I am running 2 x 6v golf cart batteries (connected in series to give me 12v.) In that case, yes, I made sure the batteries were identical, purchased at the same time and same place, since my two batteries are, in essence, forming one BIG battery (230ah of capacity.)
Sorry, but have to disagree. I run my with an isolator. Yes, parallel you also do, reason is simple, is you are isolating for specific reasons. I isolate so I can jump start my self. It premature fails them. My Interstate Dealer who sell's me batteries whole sale informed me. (I have three boats.) I buy more batteries than Wal-mart. With the boat that has diesel, you parallel just so you have enough CCA's to turn over. I have tried to do it without matching with an Isolater, and I can isolate on the Diesel Boat, it has twins, so I have several banks, and they still kill each other.
