Show off your 2015+ leveled Tahoes and Yukons!
Jenney72chevy
I couldn't find any info about 33x12.5" tires fitting. I mounted these 33x12.5x22 ridge grapplers today on replica 22x9 wheels 6.25" backspacing. The tires gave me about 1" of lift. I am running a 2.5" suspensionMaxx front and 1" rear spacer. I can make it rub at a full turn with body roll, it only rubs on the cloth wheel tub a little bit. Easy fix to just heat and push over or just pull it over with a ziptie as many others do.
DWSmoot
Charleston, SC
View attachment 182172 View attachment 182173
Looks good! Now trim the front air dam.
Jenney72chevy
Thanks. I was considering removal but access to the screws didn't look easy. Have to check more into it. May end up trimming it back instead. Also found that the sidewall barely rubs the swaybar at full lock. 6" or less backspace would be better.
AZCreeker
Look into installing a PPV front deflector that is about 1/4 of the size of the stock piece.
I did it to mine, many other people did too by now, and others have cut the stock piece
Demer
Eagle, ID
Here is my 2016 XL Denali with a SuspensionMaxx 2.25” front and 1” rear leveling kit. I wanted just a little bit of rake, and that’s what I got. I cut the air dam a few months ago as well.
Next up are 285/60-20 Duratrac tires to fill it out a bit better. I expect some heating and/or trimming to eliminate rubbing, I'll keep you updated on that one.
Baby steps towards making it the way I want it!
bigT63
Dumb question, have you tried going through a parking garage? My wife often goes to the city and into a parking garage every so often. This is the exact look I'm going for. Except my 'Hoe is Tungsten Metallic.
Jpritchie20 is the same vehicle and very similar look. Love y'all a rides.
bigT63
View attachment 182822 View attachment 182823 View attachment 182824
Could you post a close up on the trimmed air dam?
01Konvict
Boats n Hoes
Raleigh/SML
@Ridechevy09 post that new hoe on 26x16! I saw these on the gram. Give us specs but looks like FTS 10" with coilovers, specialty forged 26x16 on Fury 37s.
NGAneer
NWGA
Damn thats purdy
Aray1288
