While I 100% agree that the 255/70/15 is about the same size as the factory tire (235/75/15), the factory wheel size on the OBS 2WD is 15x7...I had 15X9 on my Suburban with 255/70/15. They are the same height as factory, just a little wider. Factory size is 15X8 with 235/75/15.
As long as you don't have drop spindles installed, you can run the 15x10 wheels on the OBS. If you have drop spindles, you'll have to trim the LCA so you can turn. Also, you're going to limit some of your tire options by going that wide (275/60, 295/50 on the street side, and 33"+ with some lift on the AT/MT side).I have a 2000 tahoe limited that i bought with 20 in rims that dont let me turn well. I was wondering if buying some 15x10 in wheels would work well with my tahoe. Are they too small?
