Denali D3S 5500k and Led hi beam and fog lights. A lot of pics inside
rlschmidt14
Nashville, TN
What's the easiest way to access the highbeam bulb, from above the engine compartment or underneath from the wheelwells?
Engine compartment. They're the caps right below the headlights. Have to take out the intake box on passenger side by disconnecting MAF sensor and one screw connecting tube to box (metal ring tensioner)
BK76
excellent write up and review. Has anyone done this to a Tahoe or Suburban? Just from the looks I can see that its different from the Tahoe and I have only seen post on Yukons and Eskys.
affliction4
Its the same process except you are using a different bulb if you do not have factory HID's.
Slow5.0
Slow5.0
Missouri
I only wish GM made running lights more whiter on these Yukons. It will be better match for led fogs and 5.5-6k HID lows
Slow5.0
Slow5.0
Missouri
Update on TRS Morimoto 2stroke Led kit. And this was on my semi truck on low beams and they are H11s. After 6 months and about 90k miles and around 1200 hrs, Leds started to fail, one side on both. But this was on semi and using them 8 hrs a day and all damn patholes around USA and wires started to break right behind Led housing. So in car they will last lifetime since I or anyone use lights as much j used on my semi. And on my Hi beam set up it will last 10 lifetimes. TRS have nice warranty, you can send them pics of destroyed Led and they will send you replacement same day or you can setup and pay for new led anf once you destroy yours, they will refund you money same day. Make sure you use good hammer because housing on these 2strome Leds are tough and cut wires so they see its not usable no more
Here is some pics how looks like when one of two led doesnt work in projector housing and pics of destroyed Leds and driver ready replacenent
fp90
Miami, FL
I just bought a Yukon SLT and did not come with the HID stock headlamps. I am new to aftermarket lighting and I wanted to see if any of you could provide me with some help.
I am looking to convert my headlamps and my fogs to LED/HID. Wondering which bulb/product I should use?
I would LOVE to have them match identically so it looks like a stock HID/LED setup. Any help? Links to products?
Thanks!!
Slow5.0
Slow5.0
Missouri
Swapped Xenon Depot PSW26W 6000k for Morimoto XB sealed LED foglights and 5202 to PSW26W adapter harness. Yes Xenon Depot were brighter but Morimoto looks nice with black housing and its just foglight , not low beam
Before and after
Xenon Depot
Morimoto XB
felixmontiel
