Front end squeak
Govtahoe
Every time I hit a bump my front end squeaks. When I turn at low speeds it squeaks for the duration of the turn. I've looked everything over multiple times. Tried adjusting the tightness of the bolts on the UCAs and it didn't help. I can't find anything to make it stop. The turning made me think it may have been power steering but it's got plenty of fluid and everything looks fine. I had a 3.5" rough country lift put on in August but it seems too delayed to be an issue from that. I'm at a complete loss. Any help would be appreciated.
01Konvict
Boats n Hoes
Raleigh/SML
Probably upper control arm bushings. There polyurethane so have to grease the hell out of them. Outside and inside plus inside holes, basically dunk them in grease and smear all over them then install. I had some squeak on my rear ones and did the same no more squeak.
Govtahoe
Govtahoe
I appreciate the quick responses. My CVs seem fine. No clicking or vibration. Passenger side is slinging grease for some reason. Going to have to look into that. I'll get some lithium grease and hose the UCA bushings down. 01Konvict, I swear you're on every post in this forum. Thanks for always sharing your knowledge.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Try lower ball joints? When mine were going, they make a creek sound. Could make it happen just by turning side to side. If you jack up he front tire off the ground, stick a pry bar between the tire and ground and pry up. Mine had a lot of play.
Also these oem joints are not greeaseable. What I also done in the past was grab a grease gun and got a needed attachment. Stab the boot and inject grease, turned side to side until it's quiet. When its all greased up use silicone and cover the puncture hole so it doesn't leak out.
If you do need joints, I'd recommend using a greaseable joint like moog
01Konvict
Boats n Hoes
Raleigh/SML
No problem dude just around to help. I'm taking a shot at the squeak but I would bet its from the arms since that's the main part that's new on the front end from lift that moves constantly.
