95escahoe
- Joined
- Aug 2, 2010
- Posts
- 5,155
- Reaction score
- 4,452
When u get random abs/brake lights on the dash. May also get a constant abs pump on too.I sent mine to a guy to fix after I pulled it. Cost like $60 but his turn time was quick and I didn't want to mess with it..money well spent IMHO.What exactly are you trying to do? And is that the Abs module?
You have this guy info. This isn't the standard abs module. This is what most of them look like. Mine has more magnets.When u get random abs/brake lights on the dash. May also get a constant abs pump on too.I sent mine to a guy to fix after I pulled it. Cost like $60 but his turn time was quick and I didn't want to mess with it..money well spent IMHO.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Oh yeah, I sent my daughter's VW ABS module out to get rebuilt a few years ago but can't remember where I sent it.When u get random abs/brake lights on the dash. May also get a constant abs pump on too.I sent mine to a guy to fix after I pulled it. Cost like $60 but his turn time was quick and I didn't want to mess with it..money well spent IMHO.
I think the pink is a heat sink material. Why did you pull it apart?I also don't see any contacts that need soder reflowed does anyone else?
Sent from my SM-N910T using Tapatalk
What are your brake RPO codes (J)? Just curious if it's related to active brake control or the 7200 brakes? I know I had to get different rear pads due to these options but not sure if it makes a diff on ABS modules.This is my abs module. Anyone seen or worked on one like this?
