quest51210
you use a hacksaw, cut off the bolt, and it presses in...i have them on mine, i cut them down because i am lowered
jcevans7
Friendswood, TX
So pulled the brake module which was pretty easy actually to get to the screws none of them were seized up. Getting it separated however has been a chore then cutting away the silicone for 40 minutes and still can't get it to budge broke off a couple pieces of plastic don't want to keep going at it and tell I know I can get it all off without breaking it more. Has anyone had this before? This is on a 2003 GMC Denali.
Sent from my SM-N910T using Tapatalk
What exactly are you trying to do? And is that the Abs module?
brian.roberts.1293
Durham NC
I think that would look good but I was avoiding painting the mesh. Prep would be so tedious. That's why I was thinking paint matched frame and bow tie or @Tonyrodz the billet Idea isn't bad
I went and my stock emblem vinyl wrapped a flat black. 20 bucks and when it gets messed up 20 to replaced it.
I finally got around to dipping my HD grille, Z-71 valance, and front & rear bumpers. Upgraded to the LED parking lights and installed the black billet grille overlay and black bowtie. I just need to put the LED fogs back in the valance.
How did then install of the rear lights go? Did they fit well? I've been looking at those for the same thing.
Sent from my SAMSUNG-SM-G935A using Tapatalk
jcevans7
Friendswood, TX
So that's the abs module. Looks different than the other ones. Way more circle magnets than the 6 that are normally shown. There are a couple write ups explaining how to side the contacts that break loose. The silicone is different than the video I found YouTube. Had to button everything up to get get my boy from school. I'll get more pics in an hour when I get it back off
If it's the kind that breaks into pieces when you try to remove it, good luck. It's a ***** and you might not be able to get it off cleanly. Some underhoid modules can't be fixed due to it.
Tahoe1844
