Two questions regarding the Nav system
David4Jesus
Augusta, Ga
I was wondering if there is a way to hook up your cell phone blue tooth to your factory nav or if its made to already do that and if so what do I need to do to get it going.
Second does the Nav system play the DVD on its screen as well and how the heck do I get the Nav system to open up to insert or remove the disc I have no book.
Thanks for your help
tx07tahoe
Houston,Tx
I want to say the 09's have blue tooth but Iam not sure. Do you have the onstar phone in your truck.
VA
theres a slit at top of deck where cd & dvd go. 07 nav deck dont have bluetooth. Google owner's manual for 07 yuk factory nav deck, u will eventually find one, I did. If pm me i could email you what I found.
---------- Post added at 06:56 AM ---------- Previous post was at 06:53 AM ----------
Oh yea, It plays dvd on screen if you are parked, unless you have lockpick install. Lockpick allows you to watch dvd while driving and enter nav addresses while driving. You can find them on ebay.
jeffbco
If your nav unit has "DVD" embossed on the bottom of the faceplate then you can play DVD's otherwise it just plays CD's. Push menu button on right side, select nav - you should see and option that swings the screen up and ejects the Nav DVD.
tx07tahoe
Houston,Tx
Do you want to change out the nav disc or watch a DVD.
---------- Post added at 03:21 PM ---------- Previous post was at 03:06 PM ----------
If you want to remove the Nav disc to put a new one in here you go.
First press the "Nav" button. It takes you to this screen. Press "OK"
Next hit the "Menu" button. And hit "Map DataBase Info."
Then hit "Change" and the screen should open up and then hit "eject"
WITCH1975
