Under back seat speaker box.
Big Tap
Houston, TX
That's a tight squeeze. I bought a JL Audio Stealth Box. It sounds pretty clean and you don't lose any cabin space.
tybardy
everyone needs a Hoe
Gilbert Arizona
JK has a nice setup, if you dont mind losing your spare... or doing a shit-lot of fab work... has anyone ever put a sub in the rear driver side "hold" (the section where the stock jack is)?
there is that circle that looks like a speaker could go their except its completely closed in. I always wondered if Chevy optioned a sub back there in that location...
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
up to 02 thats where the sub was.
tybardy
Gilbert Arizona
hey RT... you say up till 02 thats where the sub WAS.... you say that like they MOVED the sub... did they move the sub or REMOVE the sub?
Rollin Thunder
Va Beach Va
it was moved to the center console. I know there is like no bass. but its there.
Rollin Thunder
Va Beach Va
HOLD THE PHONE.... my truck has a ******* sub? how do i get to this thing, i needs replacing, its a totally *****
yea if you got bose. you got a sub. My silverados sub has been unhooked and replaced with a 1000W sub under the seat. So much better.
Modded
That Guy
Hey RT how did you get a 1000w sub to fit under the seat (which seat)?
What type is it?
Rollin Thunder
Va Beach Va
What type is it?
Its a Rockford fosgate and its in the silverado. Which has about 15" of space under the rear bench seat. Its in a custom build Ported box. amps for the speakers and sub on one side, sub on the other. Only negative is I lost all my underseat storage. The sub is only raited for 500 RMS. I know im pumping DOUBLE the reccommended wattage to it. But almost a month now and its not blown, When it blows I will put a W7 12 JL in its place.
Modded
That Guy
Oh ok I got you now, though you had it under one of the fronts.
These newer Tahoes have no good option for getting some good bass w/o either spending a forture, or taking up half the freakin car!
blueflamed03
Oklahoma
bose has the 6" sub, firing forward in the console.
Crutchfield has a QLogic box that holds downfiring 10's under the middle seat.
T
TBsTahoe
Los Angeles
Checked out Crutchfield.com and the want $250+ shipping. That's a ton for a box. I'm going to look locally. I've seen them for $100 at audio shops
WITCH1975
