spindles + drop keys
tybardy
everyone needs a Hoe
Gilbert Arizona
i presently have 2" drop keys up front (however i have them adjusted to the max so i am sitting with about 3" drops)
If i were to get 2" drop spindles would that mean my truck would sit at 5"? I am still working on improving my trucks right but do not want to drop the front any more. (maybe another 1/2" or so)
matt14
san leandro,ca
Thats how max is running his setup. I wanted to go another 1" lower all the way around, but cant get lower then 5 in the rear. I was going to lower the front a little more with some drop keys i have, but decided not to. Like it sitting level
BlizzardX23
Sacramento, California
you can install the keys but crank them to lift...so that your sitting at your current height still...but may lower them at any time...thats why I did it...
tybardy
tybardy
Gilbert Arizona
my keys are adjusted all the way down as low as they can go! i like the rake! Im more concerned with smoothing out the ride, the recent talk about having these things lowered and still riding nearly stock has me wanting more!
matt14
san leandro,ca
The problem with that is it affects your alighnment when you start cranking/decranking keys.
tybardy
tybardy
Gilbert Arizona
yea, you can give the bolt a turn or two without effecting the alignment... once you have added or subtracted 1/4" to 1/2" or more, then you are really effecting
JKmotorsports
Austin, TX
You'll be sitting about 5" lower with both keys and spindles. Honestly, mine rode about the same when I swapped from keys to spindles.
Max
Mile High
Denver
ANY time you adjust the torsion bar adjuster bolt the caster/camber will be off. I'm running 3/4 ton keys almost cranked with belltech spindles and it's 6" lower than my buddy's stock denali with the same size tire.
tybardy
tybardy
Gilbert Arizona
with that being said... is the only real solution to the ride quality adding a good quality shock?
tybardy
tybardy
Gilbert Arizona
i know we have kinda *********** about this a little already, but IIRC, billsteins dont make drop shocks... does that make a difference up front? I think i will be fine out back with the extensions... just curious
tybardy
tybardy
Gilbert Arizona
from my understanding, you can get the toe correct but the camber will be hard, possibly imposible to get 100% corrrect.
Max
Mile High
Denver
Aftermarket cams ftw. My ucas are gonne get ripped out next month, easy fix for running keys.
tybardy
tybardy
Gilbert Arizona
since we are on the subject, i want to ask something about alignment
I had my truck aligned and the passenger side was a LITTLE out of camber, but otherwise perfecto... Now, both sides are jacked, toe is out and camber is ******... can a suspension "settle in" or something? Why did this happen?
tybardy
tybardy
Gilbert Arizona
by front end... you mean..........
i guess ball joints, pitmen arms, and a bunch of other expensive *********?
Max
Mile High
Denver
Yes. Balljoints will require replacement of the entire control arm as you can't press new ones into an arm that is all wallowed out. Usually it's just the pitman arm, idler arm, inner and outer tie rod ends. Parts were $500 my cost for the napa premiums.
Jumpshot12
