strange noise
02yukonslt
ga
hello everyone i have had an 02 yukon for about 9 months now and now i have a sound that sounds like a bell but it only does it when moving at a constant speed not when accelerating. i did just put in a vett servo when the noise started but i do not think thats the cause. it sounds like it is comming from the engine compartment and i have removed both belts to see if it was the alternater,ac compressor etc. and drove up and down my driveway and the noise is still there. has anyone have an idea what it could be?
road1will
pretty pretty good
Johns Creek, Georgia
sounds like a bell?
Have you tried rotating your tires, to see if it moves the noise to the rear of the vehicle?
The fact that it only happens when moving at a constant speed makes it seem driveline related, not engine related.
Grebbler
Parts is parts...
Michigan
Check around the cats and heat shields. You may have introduced a rattle when ya did the servo.
02yukonslt
ga
well i think i found the problem. i think it is the front right shock is the cause. i can bounce one every corner and the front right is the only corner that is making the noise. what are some good shocks i can put on that will not break the bank?
Eickybobby5050
