Heated mirror switch
nurkvinny
Ok, I'll accept the laughter, ribbing, etc. if this post ends the way I am afraid it will...
I noticed this morning that my 02 Tahoe LT has heated mirror symbols on the mirrors themselves. So, I think, "cool, another option I didn't even realize I had." I look around - all over - inside for the switch that turns them on/off, but never found them.
So, while I can't believe GM would do it, did they install heated mirror glass on all Tahoes, regardless if the truck had the matching wiring / controls? Or, did someone replace these at some point in the truck's life? Or, more likely, am I freaking blind/ignorant as to where the switch is?
:think:
DenaliAK
Colder than you
Alaska
They turn on automatically when you turn on the rear defroster. There isn't a separate switch.
You're not going crazy, and you're not the first person confused by this. ;)
Rivieraracing
I couldn't figure it out when I first had my truck at first either, just push the button for the rear window defrost and they should work pretty fast!!
Divino92
Linden, MI
At the risk of sounding stupid, would it be possible to add heated mirrors and have them turn on like that? I have power mirrors already with the turn signals in them, but they don't have defrost feature. Thanks
AtomicHoe094
Atomichoe094
cleveland, OH
dont leave the defroster on too long, youll end up burning up your mirrors. I see brown mirrors on the nbs trucks everywhere here.
Rivieraracing
I think the defroster turns off automatically after 20 minutes or so, don't remember off hand though!!
---------- Post added at 04:59 PM ---------- Previous post was at 04:57 PM ----------
I would think you could if you knew how to wire the power for it to the rear window defrost circuit, only problem would be that you would have to replace your mirror glass with ones that had the defrost feature built into them.
N
nurkvinny
Thanks guys. More and more impressed with this forum all the time.
Rivieraracing
Could it be the auto dimming part of them have gone bad? I've seen a few around here as well but always figured the auto dimming went bad! Maybe someone will chime in an enlighten this conversation!
DenaliAK
Colder than you
Alaska
Mine shut off automatically pretty fast sometimes. I'm not even sure it's a timer, it might be a thermostat controlled thing.
Dangit. Now I'm going to be totally obsessed about trying to figure this out now.
Someone who knows all please stop me with your wisdom....
new203chevy
hi guy i just bought a 03 tahoe and i could not figure out if i have heated mirror i have tried looking it up but i cant find anything i am look to replace the mirrors and the ones that i see are have power and heat and there is not symbol on my mirrors i looked for that to.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
You can pop the glass out and check for wires.
JamesinAbilene
