VooDoo73
- Joined
- Jul 3, 2011
- Posts
- 22
- Reaction score
- 0
I blew a head gasket a couple of weeks ago and would up with water in the crankcase.. I didn't realize the gasket failed until 3 days later since there was no smoke out of the pipe and I falsely diagnosed a loose hose clamp as the reason I was losing coolant. It wasn't until I noticed the resevoir slowly draining as I watched it while the truck idled in the drivewaydid I realize that I was in trouble. Thanks to Mobile 1 synthetic(at least I'd like to think so) the cylider walls didn't score..Keep in mind I drive 85mi/day @ 60-80mph so I was pleasently amazed.
I had a par of remanufactured heads put on and all fluids put back in. I needed to circulate some oil for @ 500 miles then flush again for the syntec refill to make sure all of the water was out of the motor. I also needed to have the cam position sensor reset since there was a Service Engine Soon light on and I needed to have a clean engine before running her 137k mile engine up to 4000 rpm to set the sensor. Unfortunately the reset was done by my local shop through my diagnostic port.
As I drove the 1/4mi home the Service Engine light came on so back she went and a reset was attempted with no luck . It wouldn't hold the setting. The truck runs like she was new, but the light is on. My guy said that the Distributor may need to be replaced because the Mag. trigger may faulty.
I'd like to just try replacing the sensor itself for @ $30 before swapping the distributor. I can buy a new or re-man. distributor, but is the install just a 'loosen the retainer clip slide out the old -slide in the new and tighten up the clip again'? Or is it more involved?..Either way it appears that the Cam pos. Sensor needs to be set with a diagnostic connection..unless there's another way... All info is welcome.
