You are subscribed to this thread Two noises, can't figure either one out.
torsh6363
My 99 Yukon is making a whining, whirring noise when I make a right hand turn at speed. It almost sounds like a tire noise, but it occurred with both old and new tires. I also just changed the right front wheel hub assemble hoping it was a bad bearing, noise is still there. I can't even tell if the noise is coming from the front or rear anymore. Its definitely coming from the driver's side though.
The other noise I get is from the driver's side from wheel. It makes a clunking noise when making 90 degree left hand turns, especially from a stop. I've just replaced upper and lower ball joints in the front, and the sound remains. I've also checked all the steering and suspension parts up front and can't find anything loose.
I hope somebody can help me with these problems. They're driving me crazy.
Thanks,
Jim
qlc1964
qlc1964
check front& rear sway bar bushings ,shocks aframe bushings
and idler arm.
TahoeGoBoom
blue interior guy
or a u joint on the front driveshaft. Mine only did it while turning.
Jumpshot12
