Fitting 305/50/R20 .!.
TahoeLT
hello
I'm happy to register in the forum :Handshake:
my 09tahoe with stock 17 wheels
now i heve OEM 20×8.5 wheels
the OEM tire size is 275/55/20
I thinking to fitting 305/50/R20 :hands:
but without any lifting ?
is it passable or not?
and my important Q is there any problem with front tire Width when i turn max left or right ?
thanks and best regards...
Conor
"Bob's your Uncle"
Seattle, WA
I am pretty sure a 305/50 R20 will not fit. And if it did, I don't think you would like the way they would look stuffed in there. The closest size that will fit for sure is a
295/50 R20. That size would be your best bet in my opinion.
T
TahoeLT
Thanks Dear tast101 :)
Dear Conor
Thanks ... I.ll think about 295
Nat2tc
Hi all, 1st time posting.
I just put on 305x55 R20 on factory 20x8.5 wheels with no lift. Tires rubbed a little in the front when turning tight. Rubbed a little in the back when rear is compressed about 2 inches (going over big bumps!). I installed a ReadyLift 1.5 inch lift in the front and 1 inch lift in the rear. No more tires rubbing. Tires look great. Do not noticeably stick out the fender well. I'll post pix as soon as I figure out how!!!
Nat
JennaBear
Resident Ninja
San Diego, CA
I have 305/50/20s on mine. There was slight rubbing when at full crank, but a simple zip tying and you are good to go.
UofMZ71
i have 285/65/18 which is just slightly larger than 305/50/20, but slightly smaller than 305/55/20, with a 2.5" leveling kit and they rub on the right side at full turn.
I think you might have some rubbing issues if you go to that size...
JennaBear
Resident Ninja
San Diego, CA
I should have preempted my post with the fact that backspacing/offset are a huge factor in this.
WITCH1975
