Cleaning Throttle Body
992door
Greenville, NC
I was going to clean it in the tahoe and was wondering should i take it off or just clean it with it on it? i was looking at it tonight and opened it up and it is black in there should i clean it?
foreverfalcon40
I say take it off NOT that hard to do...three bolts and you can efficiently clean and dry it w/o worrying about anything getting into the manifolds and ***** shit up.
jdawg901
memphis tn.
I took mine off with no prob with b12 replaced gasket also cleaned egr while it was off also changed gasket ran a hell off alot better
---------- Post added at 06:25 AM ---------- Previous post was at 06:24 AM ----------
I meant cleaned with b12
jdawg901
memphis tn.
behind the tb on the left looks like ah flyin saucer with a vac line on top 2 bolts easy to take easier with the tb off spray it off with cleaner wipe it down replace gasket job done
961500
Is it 2012 yet?
Austin Texas
On the 96-99 vortec the EGR sits on the front of the motor between the a/c compressor and thermostat housing. Clean it and by a new gasket with a screen on it from your autoparts store to help keep it clean. If you need help pm me.
AtomicHoe094
Atomichoe094
cleveland, OH
+1 since he has a 99...
G35 2007
Do you have to take the egr valve off to clean the tb?
Jumpshot12
